Author: Subject: Pair Of Blue TRS 2" Harnesses for sale
Edwardo
posted on 26/4/21 at 06:56 PM Reply With Quote
As per title - Car is going yellow on rebuild so the blue TRS harnesses that came fitted to it are now for sale.
65 posted Uk mainland with Myhermes :-
jps
posted on 26/4/21 at 07:37 PM Reply With Quote
I am interested but have a couple of questions:
These look to be ones which bolt in - rather than clip onto an eye bolt. If i've got that right, what size bolts do they need? (I have 7/16 fittings in my car, but I know there's a metric size available too)
And do you pull those lap straps UP to tighten then - i.e. towards the centre of the body, or down - i.e. towards the end where they are bolted?
Edwardo
posted on 26/4/21 at 09:00 PM Reply With Quote
Hi - Holes in connection points are 11.25mm so would be for 7/16" bolts.
The straps pull in towards the center of the body to tighten.
Tony
jps
posted on 27/4/21 at 12:37 PM Reply With Quote
Hi Tony - thanks. Sounds like they are what I need (I have a similar set from Car Builder Solutions, but am concerned the lapbelts don't tighten with one hand, so I might fail IVA on that point...).
Did these straps go through an IVA?
Edwardo
posted on 27/4/21 at 01:11 PM Reply With Quote
When the car was SVA'd in 2002 it had some horrible short thick padded green seats and yellow belts from the pictures I've found.
The colour change to blue happened some time after 2013, so that would have been when the harnesses got swapped out for these ones.
I can't see any dates on them though - but I'm sure loads of people go through IVA with TRS belts.
Tony
Edwardo
posted on 28/4/21 at 06:45 PM Reply With Quote
Provisionally Sold To JPS
Please find pics below for the info about the strap lengths :-
Cable ties are still on where previous owner tied them out of the way - but the full strap length is there if required.
Tony
