Author: Subject: Elite IL200 6 speed sequential gearbox, Ford Type 9 fitment
se7ensport
posted on 30/5/22 at 07:12 PM Reply With Quote
Elite IL 200 6 speed sequential gearbox
Just back from Elite following a full strip, inspect and rebuild.
22KG dry weight
Upgraded helical cut gears
Fully flat & paddle shift compatible
Type 9 Mounting face 270 Nm (200 ft lbs) Maximum Torque Capacity.
Sequential gear selection, 6 forward plus reverse with pull neutral/reverse lockout.
Gearbox front face to gear-stick length adjustable between 550mm and 610mm.
Digital gear indicator system including potentiometer, wiring loom and display box.
The gearbox utilises a drop gear system to quickly alter your overall gearing without needing to change diff, currently in Option 1 configuration (see picture for ratios and option 2 gearing), other drop gears available from Elite.
Option 1
1st Gear 2.386
2nd Gear 1.636
3rd Gear 1.299
4th Gear 1.064
5th Gear 0.900
6th Gear 0.783
£3,800 OVNO.
It's located in Bristol, happy to ship.
IL200
IL200
IL200 1
IL200 1
IL200 2
IL200 2
IL200 3
IL200 3
[Edited on 30/5/22 by se7ensport]
se7ensport
posted on 2/6/22 at 04:05 PM Reply With Quote
Price reduced to £3500.
se7ensport
posted on 10/6/22 at 03:47 PM Reply With Quote
Sold.
