Author: Subject: Rx8/AJ30 project
MootchA
posted on 14/3/23 at 10:06 AM Reply With Quote
Rx8/AJ30 project
Unfortunately due to chronic health issues I have to sell my rx8/aj30 project,
Shell: stripped out rolling shell, has weld in roll cage made but not finally welded in, lowered front x member for engine space, perspex windows, roof vent, tein adjustable suspension all round, low ratio lsd axle, aluminium baffled/foam filled race tank, low pressure and high pressure pumps, swirl tank, wired and piped through to engine bay, bonnet and boot catches fitted. Was well known track car.
Engine: standard aj30, fitted with baffled and gated x type sump, st 220 manifold with modified lower inlet manifolds to give engine bay space.
2 rx8 gearboxes with levers, 1 standard, 1 modified, has 10mm taken off bell housing to accommodate aj30 spacer plate, c/w spacer plate and centre push clutch release mechanism, (new, unused). Carbon fibre prop.
Corsa pas column, not fitted
New ms 2 megasquirt, complete with coil drivers, unused or fitted, has map for standard engine fitted with lowered vvt cut off (5k) for top end power.
New unused or fitted bespoke engine loom, made and map by shaun at extra efi, can be remotely tuned to finish if needed.
2 sets of rims, 1 with good road tyres. Spare bonnet, boot and bumpers.
6 point harnesses (out of date)
2 omp first r seats, i omp seat frame, I brand new never fitted, 1 as new, perfect condition. V5 in my name.
I will break if I can get rid of everything, but would prefer someone to take the lot, finish the car and enjoy it. I dont know how to put pics on here, but I can email pics if interested. £1500:00 ono. i would deliver at cost as long as buyer has come and had a look and left a deposit.
mob: 07508391156
mike
[Edited on 16/3/23 by MootchA]
