FREE 32mm Silicone Hose, 32mm Alu pipe and Catch tank
Hi I have the following up for grabs, all free but if you can make a donation of your choice to a charity of my choice that would be great. Please
arrange own courier or free to collect from Birmingham B5 (close to city centre).
The Silicone hose is 32mm inside diameter and 42mm outside diameter, there is about 1.8 metres of it.
The Aluminium pipe is 32mm outside diameter and 28mm inside diameter, the length is approx 1.7 metres (see pic for shape - suitable for Zetec
installs).
The catch tank is 6 and a half inches in height and width the depth is 3 inches the 2 inlet pipes are approx 13mm, with a tap drain at the bottom and
sight tube on the side.
[pg]1]25872[/pg
[Edited on 17/6/23 by shindha]
