Author: Subject: front uprights
brad
posted on 12/9/05 at 06:22 AM Reply With Quote
front uprights
can the front uprights of a sierra be used instead of the cortina on a avon. If not what has to be changed
DaveFJ
posted on 12/9/05 at 07:39 AM Reply With Quote
Do you have the Avon book ?
If so it shows pictures of the Sierra uprights in use.
you will need mushroom inserts for the tops of the uprights. Not sure whether you need different wishbones ?
Tiger can confirm and supply the parts you need.
HTH
FWIW - why are you bothering with the sierra uprights anyway? it would be worth trying to get cortina ones if you can - Sierra's uprights look a b*stard when fitted...... IMHO!
[Edited on 12/9/05 by DaveFJ]
Dave
Avoneer
posted on 12/9/05 at 11:10 AM Reply With Quote
Top bone will need modding for sure as the ball joint centres are different from the Cortina ones.
Pat...
