Author: Subject: Fuel line size
Indymike
posted on 29/1/07 at 11:52 AM Reply With Quote
Fuel line size
When you guys talk about 8 mm copper fuel line, I'm assuming that you mean the inside diameter. Is that correct?
Build manual? What build manual?
sebastiaan
posted on 29/1/07 at 12:49 PM Reply With Quote
I've used 8mm outside diameter. Large enough for my application, and useable to at least 160 BHP as a guess...
posted on 29/1/07 at 01:56 PM Reply With Quote
generally it is the outside diameter (or inside if it is hose) since that is how you'll get stuff to fit.
if you had 8 mm inside id pipe, what size hose would you use ??????
TangoMan
posted on 29/1/07 at 11:43 PM Reply With Quote
8mm OD as has been said. I guess this is around 6.5mm ID.
At 45psi that will flow a serious amount of fuel. Enough for 99% of Locosts. I can only dream of being in that 1%
Summer's here!!!!
DaveFJ
posted on 30/1/07 at 01:32 PM Reply With Quote
as my future upgrade plans may contain a cosworth engine I went for 10mm from the outset.........
Dave
supercat
posted on 18/2/07 at 07:07 PM Reply With Quote
Can anyone recommend a decent (online preferably) retailer of different sized fuel line?
Cheers.
