Author: Subject: weight
milton
posted on 5/6/07 at 09:16 AM Reply With Quote
weight
how do you get the front and rear weights for the SVA. not that iam any where ready but will file info away
cheers
stevec
posted on 5/6/07 at 09:44 AM Reply With Quote
The general practice is to put down about 450Kgs for each axle, this will ensure you will be OK for brake testing weights,
Steve,
nitram38
posted on 5/6/07 at 09:47 AM Reply With Quote
They are not after actual weights, they are after design weights. This is the maximum that each axle is designed to carry. I used 550kg rear (engine at back) and 400kg front.
Someone will be along with the correct numbers for your car.
Get it wrong and the sva will fail you as they use the design weights when calculating brake efficiency. You don't want it too high, but giving weights too low will fail too.
russbost
posted on 5/6/07 at 12:12 PM Reply With Quote
The SVA manual shows how to check it out & you can do the calculation which they will do at the test, you want to have the weights low enough to pass the brake test, but high enough that you won't run into "overweight" probs on either axle as this results in having to make a fresh application with new weights I believe!
NS Dev
posted on 5/6/07 at 12:55 PM Reply With Quote
exactly. I used 450kg front and rear as this gives a fair bit of spare and it passed the brake test with ease at that
wicket
posted on 5/6/07 at 09:56 PM Reply With Quote
Declared 450kg front and rear gross weight 900kg. Actual weight at SVA 304kg rear and 308kg front, passed SVA ok
[Edited on 5/6/07 by wicket]
