Author: Subject: Fuel tank design
R1FREESTYLE
posted on 30/11/07 at 07:49 PM Reply With Quote
Fuel tank design
Hi Folks,
I am going to have a tank made to fit in my R1 powered buggy.
My questions are:
1, What size should the "unleaded restrictor" be in the filler neck/ tube?
2, How far down the tube should it be? i.e. how much fuel pump at the filler station needs to go inside the tank?
3, The areo cap I am using has a beather in it, do I need another breather outlet near the top of the tank and a breather pipe to hang below the floor line?
The car is to be SVA'd so I need to meet all the requirements.
I have attached a pic in an effort to describe what I mean in my first 2 questions.
Pokin the grim reaper with a stick........then running away!
RazMan
posted on 1/12/07 at 11:01 AM Reply With Quote
I think the leaded nozzle is 25mm dia so around 22mm would be good.
The distance down the neck is pretty flexible - it has just got to prevent the leaded nozzle from being used. I think mine is about 30mm down.
If your cap has a breather then you won't need another one on the tank.
HTH
[Edited on 1-12-07 by RazMan]
Raz
R1FREESTYLE
posted on 1/12/07 at 02:31 PM Reply With Quote
Thanks Raz man..........
