sammy
posted on 2/12/07 at 07:09 PM |
Single or twin brake master cylinder?
I am making my own floor-mounted pedal box, and am wondering whether to use a single (combination) master cylinder or twin master cylinders with a
bias bar for the brakes.
Is there any real advantage on a road car to having twin master cylinders? I have sierra drum rear and cortina front calipers so braking isn't
going to be great anyway!
Build diaries...
Mr Whippy
posted on 2/12/07 at 07:34 PM |
I got the twin bias’s bar jobby and to be honest I would never ever get another. Just a total caper to adjust and rather crude contraption. I'd
much prefer a normal dual master cylinder with a bias valve for the rear instead. Also alot cheaper in the end.
You might just get away with no bias adjustment seeing your using drums at the back anyway. If I were you I'll just wait till you try it out and
if it locks at the back just install the valve. I think you can get better pads for the front, green pads comes to mind but the brakes will be fine
for such a light car.
[Edited on 2/12/07 by Mr Whippy]
sammy
posted on 2/12/07 at 07:40 PM |
Thanks for that Mr Whippy it's kind of what I was thinking, the bias bars look a bit fiddly although I must admit I've only seen pictures.
Build diaries...
DavidM
posted on 2/12/07 at 07:41 PM |
I'm using an Escort non servo master cylinder with Cortina discs at the front and Escort drums at the rear. It's fine for road use. I
think you'd be suprised how good the set up is in a car as light as a Locost.
Werner Van Loock
posted on 2/12/07 at 07:49 PM |
If you intend to keep the drums, use single master cylinder, the dual setup has no advantage and more possibility on problems and a possible sva fail
if not done right, ie locking the adjusting mechanism and making sure balance is right.
http://www.clubstylus.be
posted on 2/12/07 at 07:52 PM |
A balance bar system is just a temptation to twiddle -- potentially very dangerous for road use.
For track use it is a diffeent mater they are far from crude and give very fine adjustment of front to rear balance.
Fatgadget
posted on 2/12/07 at 08:33 PM |
I thought the reason why a dual braking system is one of fail safe?
Bluemoon
posted on 3/12/07 at 09:40 AM |
Single in this case is actuality a dual circuit cylinder, i.e. standard fitments. Dual in this case is referring to two separate cylinders. Both are
dual circuit.
Dan
RazMan
posted on 3/12/07 at 11:58 AM |
I find the bias bar setup very fiddly to install but easy to adjust (you can get a dash adjuster which makes it even easier)
Having said all that, I will be going for a compensator valve next time.
In either case it is vital to do your calculations before buying the brakes - I ended up a little overbraked on the front despite winding the bias bar
to the rear.
Raz
