this_year!!
posted on 20/1/08 at 06:14 PM |
Rear drum parts / front hub parts?
Hi all, 3 things to ask if I may?
I am looking to replace the little rubber parts on the back plates that cover the exit of the handbrake mechanism.
I just wondered if anyone knew where to get them?
I am looking to replace the little metal centre covers on the front hubs (Cortina) are these still available?
Finally the small strips that go inside the front hubs that you lift to lock off bolts for the discs, can you still get these?
Thanks in anticipation,
Rich
[Edited on 20/1/08 by this_year!!]
big_wasa
posted on 20/1/08 at 06:36 PM |
caliper and discc tab washer kit
Confused but excited.
posted on 20/1/08 at 07:19 PM |
I need the same parts.
The rubber gaiters are like hens teeth.
I bid over £15 for a second hand pair on ebay and didn't get them . I was expecting to get them for under a tenner.
The grease caps can be obtained but nice, as new ones, seem to go for daft money as well.
I have decided to make my own tabs.
this_year!!
posted on 20/1/08 at 09:17 PM |
rear axle parts ?
Cheers Big wasa, that's the locking tabs out of the way just the other items to find - I have managed to come across the centre grease caps at
Westfield so will probably purchase those - but I am still having no joy tracking down the small rubber covers for the rear axle if confused is
correct and they are like hens teeth then I am in for a long wait!?
Rich
posted on 20/1/08 at 09:37 PM |
Might be worth getting in touch with someone like Pastparts in Bury st Edmunds? Or check out Practical Classics mag for specialists for the rubbers
IIRC they are Girling parts?
this_year!!
posted on 20/1/08 at 10:15 PM |
rear axle parts ?
Thanks Rusty, have sent both an email to see if they can provide or at least point me in the right direction. Hopefully I will be able to post soon
with an answer.
Rich
this_year!!
posted on 21/1/08 at 04:41 PM |
Rear drum parts?
No luck I'm afraid - I have phoned everyone I can think off ! One guy knew exactly what I was speaking about but hadn't had any of the
parts in for 10 years!!
Anyway I am going to pop into the old newsagents and have a quick shufty at a classic ford mags to see if that helps, if anyone else has any ideas
please let me know.
Rich
iank
posted on 21/1/08 at 04:59 PM |
Don't know if they are the same size, but you can still get ones for mini drum handbrake levers.
http://www.minispares.com/Product.aspx?pid=36299
Maybe a trip to the scrapyard might find an alternative source.
Anonymous
this_year!!
posted on 24/1/08 at 09:11 AM |
Rear Drum Parts
Confused but Excited, if you need those grease caps - they aren't that expensive I have found direct from Westfield...
Didn't know if you'd tried there or not.
Rich
posted on 24/1/08 at 06:27 PM |
Worth a try, cheers Rich.
The last time I tried to get something from Westfield, I was told to sod off, because I couldn't provide them with a chassis number.
this_year!!
posted on 24/1/08 at 09:50 PM |
I think they must've given up now with the amount of 7's out there they either beat em or join em... needless to say they joined them and
this is their comment in their parts store...
"All of the components used to make the now famous and respected Westfield kit car brand are freely available for sale to any kit car
enthusiast, whether building/maintaining a Westfield or not"
Rich
