posted on 20/1/08 at 08:45 PM |
WILWOOD SPOT CALIPERS - SOLD!
NEW & UNUSED WILWOOD SPOT CALIPERS - £75 DELIVERED (COST JUST UNDER £100
WHEN VAT AND DELIVERY ADDED)
[Edited on 21/1/08 by scootz]
[Edited on 30/1/08 by scootz]
blakep82
posted on 20/1/08 at 08:50 PM |
are these good for handbrakes? i'm thinking of using the same calipers they use for racing on the back axle, but the calipers don't have
handbrake built in, so i was going to have these too
________________________
posted on 20/1/08 at 09:01 PM |
That's all they do Blake... handbrake function.
blakep82
posted on 20/1/08 at 09:05 PM |
yeah, the reason i ask though is because the pads look quite small. just thinking what size car can the hold on a hill a seven should be no
problem, think mine's going to be a bit heavier you see.
posted on 20/1/08 at 09:10 PM |
Ah... yes!
posted on 21/1/08 at 01:56 PM |
Still available.
jammy_basturd
posted on 29/1/08 at 10:58 AM |
Hey, I believe the Wilwood literature says these can't be used on a disc diameter less than 9" I think. I'd need them to go on a
disc between 7-8", could you see any reasons why they wouldn't go on a disc this size?
Thanks.
posted on 30/1/08 at 08:52 AM |
Don't see any reason - I trial mounted them on 9mm discs and there appeared to be much more grip available - certainly a couple of mm.
posted on 30/1/08 at 09:53 PM |
Sorry James... they sold earlier today - not got round to updating the ad,
Thanks for your interest and apologies again.
