Author: Subject: UPDATED garage clearout BEC bits and more
locoboy
posted on 18/2/08 at 10:05 PM Reply With Quote
4xv R1 CDI
cdi
cdi
205 header tank
205 header
205 header
Ford header tank
ford header tank
ford header tank
Ford washe bottle
ford washer bottle
ford washer bottle
R1 fuel cap and housing
R1 fuel cap
R1 fuel cap
Kawasaki 1000cc fuel pump
Small master cylinder suit BEC clutch etc
NEW never fitted R1 clutch cable
R1 flasher unit, it powered 6 normal car flashers and passed SVA
R1 1998 fuel sender may fit others too
R1 fuse box 1998 may fit others too
R1 headlight loom allows plugging in of switchgear and holds the headlight relays etc.
Headlight relay, i have 2, one for hi and one for low beam
LH switch gear
R1 haynes manual
R1 1998 relay cluster
RH switch gear
Race tech mirrors the 2 bolt boss can be taken off to leave a one bolt fixing
Sealed beam 7 inch no sidelight provision though
Sierra Master cylinder
SVA manual SOLD pending PAYMENT
ALSO HAVE
R1 Airbox complete with rubbers and clips
£10 + PnP
OFFERS please, postage to be added or collect from Telford.
They will be on ebay if they dont go on here.
Have fun.
[Edited on 19/2/08 by locoboy]
[Edited on 25/2/08 by locoboy]
Locoboy
K999NNY
posted on 18/2/08 at 10:09 PM Reply With Quote
How much for the filler cap and do you have a pic of the back? What size diameter is the filler tube?
locoboy
posted on 18/2/08 at 10:19 PM Reply With Quote
You have U2U K999nny
Locoboy
Confused but excited.
posted on 18/2/08 at 10:23 PM Reply With Quote
U2U sent re- AA badge.
bob tatt
posted on 18/2/08 at 10:32 PM Reply With Quote
need some dimensions on the filler cap if its not gone cheers rob
locoboy
posted on 18/2/08 at 10:33 PM Reply With Quote
Its not gone as yet, will post dims tomorrow - too cold for me to go to the garage!
Locoboy
caber
posted on 18/2/08 at 10:54 PM Reply With Quote
Fuel pump , Master cylinder and Pug header u2u sent!
Caber
locoboy
posted on 19/2/08 at 07:13 AM Reply With Quote
Caber U2U sent
Locoboy
madrallysport
posted on 19/2/08 at 09:50 AM Reply With Quote
u2u sent re-steering wheel boss
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
locoboy
posted on 19/2/08 at 10:30 AM Reply With Quote
U2U back tp you rallysport
Locoboy
Browser
posted on 19/2/08 at 01:30 PM Reply With Quote
U2U sent re: mirrors
jimbona2
posted on 19/2/08 at 01:32 PM Reply With Quote
how much for the santa lady?
locoboy
posted on 19/2/08 at 06:08 PM Reply With Quote
you will never offer me enough money to let her go.
Locoboy
locoboy
posted on 19/2/08 at 06:10 PM Reply With Quote
For those wanting more info on the filler i have it here
filler1
filler1
rear of filler
rear of filler
The dimension of the hole on the front face is approx 77mm.
The dimension of the hole in the rubber is approx 52mm.
Hope that helps.
Locoboy
locoboy
posted on 25/2/08 at 10:24 PM Reply With Quote
Bump
Locoboy
