mcerd1
posted on 9/4/08 at 01:18 PM |
leftover donor parts - Stoneleigh 2008
One way or another I'll be at stoneleigh again this year in a tin-top
I've got a few leftover sierra/ granada bits including:
1 pair granada driveshafts (lobro type no joints)
2 used 100mm type lobro joints
2 pairs granada front uprights (no hubs)
1 type 9 bellhousing (iron 4cly type)
mk3 granada bits - trim, electrical, switches, instruments, wheels (5 stud 14" steel).........
various pinto bits:
2 heads, 2.0 carb'd type
2 blocks, 2.0 carb'd type (both with a stuck piston ! )
1 std crank (might need reground)
std carb'd type conrods (with old pistons still on them)
also a couple of sumps (one rusty ), used oil pumps, pickup pipes, pulleys, used cams, covers, bolts etc.......
probably loads more too, feel free to ask
shout if your interested in any of it - I dig it out and post a pic
-Robert
ps - I'm not looking for much ££, some things are worth a couple of beer tokens - alot of it you could have for £Free
[Edited on 23/4/08 by mcerd1]
ChrisW
posted on 9/4/08 at 01:40 PM |
Fuel pump?? (if it was injection, and had an external pump)
Chris
mcerd1
posted on 9/4/08 at 01:54 PM |
should have 2
there still on the cars, one did work about a year ago, the other I've no idea
I'll have a look and see what they are like
ChrisW
posted on 9/4/08 at 06:50 PM |
If you have two, and they both work, I'd be interested in them both.
Let me know what you find, and how much.
Cheers, Chris
mcerd1
posted on 9/4/08 at 07:28 PM |
assuming they work and you pick them up at stoneleigh - call it 50p each
quote: Originally posted by jollygreengiant
I know it might sound silly but would you have (still) the top part of the fuel tank, the bit where the fuel sender unit fits in and about 3 inches
around it. Beer tokens available.
the tanks are still in the cars (and have fuel in them ) - it will depend if I can get them out in time, and what I find once there out......
[Edited on 9/4/08 by mcerd1]
ChrisW
posted on 9/4/08 at 07:34 PM |
No chance of getting them sooner? I'll happily send DHL to collect from your door!
Chris
mcerd1
posted on 9/4/08 at 09:32 PM |
maybe - but I don't know when I'll get a chance to take them off & test them (I'm away again this weekend)
mcerd1
posted on 11/4/08 at 02:29 PM |
svenkev - u2u sent with pic
mcerd1
posted on 23/4/08 at 08:23 PM |
I'll be getting any bits sorted this weekend so let me know before Sat if anyone want anything.....
mcerd1
posted on 28/4/08 at 06:01 PM |
Just a quick check, did you manage to sort out the Fuel tank piece mate.
not yet
I've got one tank half out at the moment (for the fuel pump for chris) I'll let you know later in the week what condition that bit of the
tank is in (I can't see it yet)
.....$*@#ing rusty old pile of ford %^*!
mcerd1
posted on 2/5/08 at 05:57 PM |
chris - I've got the fuel pump off, Ill test it later and drop you a u2u
JGG - I've the sender out with about 1.5"-2" round it - u2u sent
MikeR
posted on 3/5/08 at 07:11 PM |
bit late on the notice - but how much would you want for the drive shafts and joints?
May help me going de-dion with my drums if i can mix and match.
