Still FS: Lexan flyscreen
This is the one I have had on the car for only a month - I have decided to go "proper" aeroscreen so it's surplus to requirements.
It is used, i.e. there may be a few minor scuffs, etc.
Bottom edge shaped to fit ST scuttle with ledge - may fit others e.g. MK.
It has 3 holes drilled in the bottom edge where it was fitted to my car.
5mm thick clear Lexan
86cm wide from point to point
19cm high in the centre
This is taller than most, but you could obviously cut it down if you wanted it shorter.
Say £10 + P&P, or handover at Detling this wekend.
U2U or email me
Simon
