Author: Subject: seat padding
pewe
posted on 30/5/08 at 10:58 AM Reply With Quote
seat padding
I've searched high and low for some reasonably priced padding for my GRP bucket seats to provide some warmth on cold days and stop bum slide.
I've come up with a source but had to buy a bulk quantity so anyone want some?
It's Black neoprene with a high tack, high strength, self-adhesive backing.
Sheet size is 275 x 345 x 4mm and I'm looking for £6 per 2 sheets plus postage of £1.50.
FYI the best price I found from a certain seat manufacturer was £6/sheet of 5mm!
U2U me if interested.
Cheers, Pewe
Later - Tried taking a pic. but to be honest it just comes out as two black oblongs. I reckon on using the 2 sheets per seat - one under the bum area and then cut the other sheet into four strips - a couple of strips down the sides and a couple on the seat back - chaqun a son goo as Delboy said!
Cuts with a pair of scissors and being Neoprene (wet suit fabric) it's more durable than foam but obviously it's not like PVC or ali.
I think the high tack backing will last quite well as it has a woven membrane in it.
Can't say more than that as I haven't used it myself but it seems like a good solution.
[Edited on 30/5/08 by pewe]
Blackbird Rush
posted on 30/5/08 at 12:12 PM Reply With Quote
How may sheets do you have?
How easy is it to cut?
How many sheets do you think you would need to do a pair of seats?
Prob be interested in some....
Ash
se7ensport
posted on 30/5/08 at 12:16 PM Reply With Quote
do you have any pics of the stuff? and what is its intended use?
I'm already using some kind of foam on mine, however, it damages quite easily.
charlierevell
posted on 30/5/08 at 01:00 PM Reply With Quote
I'm interested but would like to see it if possible...
Tango orange is an 'IN' colour!!
Stuart_B
posted on 30/5/08 at 01:40 PM Reply With Quote
hi, i am intrested
how many sheets do you need for to seats?
thanks
stuart
tim windmill
posted on 30/5/08 at 03:38 PM Reply With Quote
is two sheets sufficient for a pair of seats?
if so i will take some if stll available.
eccsmk
posted on 31/5/08 at 10:25 AM Reply With Quote
recievd thankyou kindly
Taz Surfleet
posted on 31/5/08 at 12:52 PM Reply With Quote
any more still available ?? need 4 sheets if it is !!
indyian
posted on 31/5/08 at 08:53 PM Reply With Quote
hi si there any more of it left i interestid
