carlknight1982
posted on 3/6/08 at 08:32 AM |
For Sale - 4 spd Type 9 box
4 speed type 9 gearbox, pinto bell houseing and good clutch, no gear lever
offers
untested but came with a good engine so believed to be good, im replacing it with a 5 speed
viatron
posted on 3/6/08 at 08:41 AM |
as an aside what vehicle did this come out of? we run one in our racer and have found it a good strong box but never did find out what vehicle it came
out of. how much are you asking might have it as a spare
mcerd1
posted on 3/6/08 at 09:07 AM |
4spd - surely thats a type E rather than a type 9 then :?
click
[Edited on 3/6/08 by mcerd1]
viatron
posted on 3/6/08 at 09:19 AM |
i thought this but the type e has the gear lever held in with the round clippy type thingy where as the type 9, including our 4 speed has the 3 bolt
arrangement
carlknight1982
posted on 3/6/08 at 09:39 AM |
not sure, i believe it to be a cortina 2000e
indykid
posted on 3/6/08 at 09:57 AM |
it's a type 3 then, not a type 9
tom
mcerd1
posted on 3/6/08 at 12:06 PM |
type 3 would be my guess too
as found in Mk2/3/4 cortina's, Mk1 capri's and 1.6 sierra's acorrding to butrons site:
linky
carlknight1982
posted on 3/6/08 at 12:39 PM |
how would i find out exactly? the guy told me type 9 4 spd
now im curious
BearingKits
posted on 3/6/08 at 01:31 PM |
If it has a 3 bolt fixing on the stick like T9 but still 4 speed it will be from an early 2.0 Sierra
It was a hybrid of the Type 9 and 4 speed 2.0 Cortina / RS2000
It should have Type 9 synchro rings, 3rd 4th selector hub and input shaft but the rest of the box was mostly early parts.
www.Bearingkits.co.uk
Gearbox, Differential and Axle rebuild parts.
meany
posted on 3/6/08 at 01:58 PM |
this any help.
http://www.zetecinside.com/xr2/gearbox.htm
miikae
posted on 3/6/08 at 02:12 PM |
Type 3-4speed-7/8"x20 spline input shaft
Type E-4speed 1"x23 spline input shaft (rocket)
Type 9-5speed 1"x23 spline input shaft
Type E & T9 have the same gearstick fittings 3 bolt , i keep an E as as spare , T9 fitted in place of the E straight swap , apart from rubber
mount .
Mike
[Edited on 3/6/08 by miikae]
If it can be done it i will be done .
indykid
posted on 3/6/08 at 08:01 PM |
the pictures are wrong on the burtons site in that case.
i based my type 3 suggestion on the gerastick mounting flange being the same.
tom
procomp
posted on 4/6/08 at 07:35 AM |
Hi yep the burton site as good as it is is not that accurate.
As BearingKits says it is a hybrid type 9 Or a codge of the bits that where lying around ford at the time that would take the power of the 2.0l
sierra.
It will have the same gear ratios as the 5 speed Ie: 3.65 1st 1.97 2nd 1.37 3rd and 1 4th OTTOMH.
Cheers Matt
mcerd1
posted on 4/6/08 at 12:14 PM |
ford have aways been good at bodging together the leftovers - so it makes it nearly impossible for anyone to have a completly accurate list of what
they built
