Author: Subject: Alloy hub studs
Pdlewis
posted on 12/7/08 at 07:32 PM Reply With Quote
Alloy hub studs
Hello,
Ive been trying to find somewhere for the last couple of weeks that can push the studs into my olloy hubs without any luck, is it possable to draw the stud through using a wheel and nut? or is that a silly idea?
thanks
Paul
Build Photo Album
Updated 05/02/2009
clairetoo
posted on 12/7/08 at 07:39 PM Reply With Quote
That's just what I did...................
Its cuz I is blond , innit
Claire xx
Will weld for food......
jacko
posted on 12/7/08 at 07:51 PM Reply With Quote
use the wheel; nuts and washers
liam.mccaffrey
posted on 12/7/08 at 07:57 PM Reply With Quote
I used a socket as a spacer and pressed them in with a vice.
be careful though with the alloy hub and the stud splines
Build Blog
Build Photo Album
Fatgadget
posted on 12/7/08 at 08:03 PM Reply With Quote
^^ That is how its done by the professionals. Years ago I was at David O'Brians workshop-the man behind Race and Rally transmissions.Lo and behold I spotted a pimply apprentice doing just that to Group 4 alloy hubs that were destined for Ari Vatanens Rothmans Escort!
As Liam I did 2 of mine (2 missing on each rear drive) with vice but they did not go in square - fortunately I was just about able to get the wheel on and pulled them using wheel nuts - whcih trued them up.,
so whilst its sound like a good idea, my own experience says you are better off pulling using a wheel.
indykid
posted on 12/7/08 at 08:04 PM Reply With Quote
grease the threads of the stud well if using a wheelnut and washers or it makes real hard work of an otherwise easy job.
tom
Richard Quinn
posted on 12/7/08 at 10:32 PM Reply With Quote
I did mine using an old wheel nut and a couple of washers. Greased the threads and the washers first and it was relatively straightforward.
viatron
posted on 12/7/08 at 10:33 PM Reply With Quote
did 8 studs in 2 ally hubs using a wheel and wheel nuts only this afternoon, a good long breaker bar makes it easier
[Edited on 12-7-2008 by viatron]
