Author: Subject: Entire 2.0l turbo drivetrain
Jesus-Ninja
posted on 11/8/08 at 05:14 PM Reply With Quote
SOLD
Entire SR20DET engine and drivetrain from my S14 (see avatar) will be up for grabs soon.
Not sure what the rules are on asking for offers, so if I'm breaching the locostbuilders' forum rules, then I apologise. That said, I'm not sure what it's worth really....
Stage1 SR20DET engine
Roller bearing T28
Gasflowed and ported head
1.8mm metal head gasket
Cold plugs
19 row oil cooler
After market water temp and oil pressure and temp sensors fitted and gauges
Solid nylon engine mounts
CynRG ally flywheel + clutch
Sard R2D2 dump valve with custom recirc
Adjustable boost valve
Apexi filter
3" stainless downpipe
3" (stock) Cat
2"x12"x24" FMIC + hose / ally tubing
Large ally rad
Stage 1 ECU
Wiring loom
Walbro fuel pump
Gearbox with short shift, prop and Stock Diff with viscous LSD (no driveshafts though)
Having been told at Surrey Rolling Road (who give "real" figures, rather than pub talk) "you'll not get more than 250 real BHP", it spun the rollers to 263.
Last action it had (a fwe weeks ago) before being removed can be seen here (the spin was driver error.... ) http://www.youtube.com/watch?v=mftt-tSW_ec
[Edited on 13/8/08 by Jesus-Ninja]
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
mr henderson
posted on 11/8/08 at 05:24 PM Reply With Quote
Whatever anyone will pay for it.
That said, I'm sure you are much more familiar with this sort of thing than most of the people here, so it probably would be better if you gave at least a ball park figure
John
Jesus-Ninja
posted on 11/8/08 at 05:44 PM Reply With Quote
Originally posted by mr hendersonWhatever anyone will pay for it.
Very true!
OK, as a finger in the air for the components:
engine 500
gearbox 150
rad 50
oil cooler 50
dv 40
diff 50
prop 30
mounts 15
ecu 50
intercooler 50
filter/downpipe 100
fuel pump 30
loom 20
Totals 1135
A nice round 1k then
posted on 11/8/08 at 05:55 PM Reply With Quote
For a stock engine there's a going rate. For tuned engines it really is whatever someone will pay for it.......
Pezza
posted on 11/8/08 at 08:30 PM Reply With Quote
oooo that is tempting to drop in the escort
I'll go check my finances.
Where abouts are you located matey?
Ben
[Edited on 11-8-08 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
Jesus-Ninja
posted on 11/8/08 at 08:40 PM Reply With Quote
Not a million miles from you. Orpington, Jn4 M25.
As I've whet your appetite, a couple of things..
1 - the diff is still in the car, so I'll have to drop that out
2 - the gearbox has a bit of a crunch if you block shift from 3rd to 5th
3 - the fuel pump is still in the tank, but if you wanted, ,you could take the whole tank with you! (no extra cost)
You're welcome to come and have a nosey, with no comitment, any time.
[Edited on 11/8/08 by Jesus-Ninja]
Pezza
posted on 12/8/08 at 06:20 AM Reply With Quote
That'd be handy i'll have to check with the boss what day would be best to pop up.
I'll get back to you
Jesus-Ninja
posted on 12/8/08 at 07:45 AM Reply With Quote
Cool - best bet might be for you to drop round to inspect, and then if you're interested, I'll drop the diff out when I can, and the tank (which is a bit harder, as I need to remove the rear subframe), and then I can deliver it all to you in one.
If you like.
Jesus-Ninja
posted on 13/8/08 at 07:33 PM Reply With Quote
Sold!
