Author: Subject: Rear Arch Fitment
SJC
posted on 21/8/08 at 04:39 PM Reply With Quote
Rear Arch Fitment
Hi
Just want to see how people have fixed rear arches on?
I will beat you to the nuts and bolts answer !!!!!
Was trying to find some pics as well, anybody got any that can share with me ??
Many thanks
Stu
iiyama
posted on 21/8/08 at 04:51 PM Reply With Quote
M6 flanged nuts and bolts but not steel, nylon!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
saigonij
posted on 21/8/08 at 05:42 PM Reply With Quote
M6 nuts and bolts with large diameter washers to spread the load.
jollygreengiant
posted on 21/8/08 at 05:48 PM Reply With Quote
M6 Stainless steel nuts, bolts and penny washers.
tomgregory2000
posted on 21/8/08 at 06:17 PM Reply With Quote
Ive just fitted my arches, had the day off work and got them all done now with lights fitted, i was worried that i would get them in the wrong place as there such a big bit but it all went well with no probs, i used M6 X 25mm hex s/s bolts with penny washers and nyloc nuts and the tadpole rubber between the arch and the bodywork.
Good luck
Tommy
perci
posted on 21/8/08 at 06:25 PM Reply With Quote
rear arch fitment
Dont forget to put the wheels on the car first to get correct position, ie, centre the arches to the wheels rather than position to the bodywork, we used stainless nuts and bolts with stainless penny washers, best of luck, pete and bec.
posted on 21/8/08 at 06:36 PM Reply With Quote
At the recent Newark show every Luego there had the rear arches fitted differently I got my car sitting on its wheels the centralised the arch measuring from the center of the wheel with both front and rear edges level with the side and rear panel. Looks better than a huge gap above the wheel IMHO
Paul (Notts)
posted on 21/8/08 at 06:45 PM Reply With Quote
I like mine the way they are
Nowt wrong with big gaps
tootall
posted on 21/8/08 at 10:00 PM Reply With Quote
i put mine on last month spent ages measuring and marking them out did a reall neat job with piping round and everything made the car look nearly finished.
The car is still up in the air and i got a set of new rear disks and pads and fitted them with new bearings last night! i put a wheel on to check bearing was fitted right and then realised my arch is not central its nearly a inch out !!!!
so im not happy today did touch the car today just turned lighs off and went home
some people dream of sucsess, others just get on and do it !!
