mikeb
| posted on 2/9/08 at 03:23 PM |
Silencer rolled end
Do exhaust silencers need a rolled end to pass SVA now?
I have seen this one from an old westie but not sure if its suitable?
Mike
indykid
| posted on 2/9/08 at 04:15 PM |
it will need a rolled end, so no, it's not suitable as is.
tom
Russell
| posted on 2/9/08 at 04:27 PM |
Yes, rolled end needed on the tailpipe but Mr SVA won't like the edges of the can itself either.
Cheaply and easy enough to sort though. I edged mine with split 8mm Kunifer fuel pipe.
I'm a bilingual illiterate. I can't read in two languages.
mikeb
| posted on 2/9/08 at 04:51 PM |
Have you any pictures of your modified silencer? Was the pipe plastic/rubber or metal and how did you attach it?
For £35 delivered is this one worth a punt?
Mike
piddy
| posted on 2/9/08 at 05:08 PM |
You could always buy one of those after market tail pipe finishers from your local car parts shop.
robinj66
| posted on 2/9/08 at 05:47 PM |
That's what I did - I bought a bit of exhaust trim for £4 at the peterborough show, cut it down and welded it into the end of the pipe.
Pic shows it before welding
[img] [/img]
Russell
| posted on 2/9/08 at 08:19 PM |
Here's how I did it. On close inspection its looking a bit manky 4 years on from SVA. S'pose I could take it off...
Image deleted by owner
Russell
| posted on 2/9/08 at 08:21 PM |
Oh, and I did the same to the ali side panel where the exhaust enters. That bit still looks OK.
hellier0437
| posted on 2/9/08 at 09:07 PM |
just wondering, did you not have to put some sort of heat protection on the exhaust pipe where it comes out of the car?
robinj66
| posted on 2/9/08 at 09:41 PM |
Russell
Did you just crimp the split tube on or did you fix it in some other way.
I tried with normal brake pipe but the result looks (and is) kak
Russell
| posted on 3/9/08 at 09:02 PM |
Shaped it first so it was a good snug fit then kinda crimped it on gently. Been there for 4 years without falling off.
