Avoneer
| posted on 28/9/08 at 07:05 PM |
Garage Clear Out
2 x lengths of blue cotton braided fuel hose. 7.5mm id. 12.5mm od. 810mm long & 950mm long. £3.00 posted
2 x battery terminal covers. £1.00 posted
2 x used and still useable Escort rack rubbers £4.00 posted
8 x new dzus type fastners £5.00 posted
1 x M16 pad fitting kit for two calipers £5.00 posted
1 x Racetech removeable steering wheel centre with only 1 hole drilled £5.00 posted
5 x Escort Wheel Centres £7.50 posted
2 x Transit top ball joint locking nuts £3.50 posted
5 x 4 pin relays £5.00 posted
2 x Metro bonnet vents with flush bottoms £7.50 posted
2 x Racetech mirror scuttle mounts - adjustable angle £5.00 posted
1 x mini rear view mirror £4.00 posted
1 x suction rear view mirror £2.00 posted
8 x M8 head studs £7.50 posted
4 x various cable ends £6.50 posted
1 x Sierra brake reservoir connector £3.00 posted
2 x Mk2 Escort brake back plate grommets £10.00 posted
6 x very strong magnets 7mm x 5mm £3.00 posted
2 x Sierra column bearing retaining cock rings £2.00 posted
18 x hard nylon bushed (only 17 pictured). Some with the odd insertion mark, but never been fitted to a car. 25.8mm od. 14mm id. £7.50
posted
OPEN TO OFFERS ON EVERYTHING
  dzus oct
  caps oct
  relays
  oct
  bush oct
oldtimer
| posted on 28/9/08 at 07:11 PM |
u2u sent re mirror
meany
| posted on 28/9/08 at 07:25 PM |
u2u sent re: locking nuts and bushes.
RichieW
Can I have the steering rack rubbers and transit lock nuts if they haven't gone yet?
Edit ooh too late again...
[Edited on 28/9/08 by RichieW]
Can I have the nrake reservoir connector too?
A further U2u sent
24vseven
| posted on 28/9/08 at 07:26 PM |
u2u on wheel centers
panichat
| posted on 28/9/08 at 07:30 PM |
U2U
U2U for Dzus type fasteners.
Dave
dave-69isit
| posted on 28/9/08 at 08:05 PM |
parts
hello pat interseted in brake fittin kit please
Avoneer
| posted on 28/9/08 at 08:10 PM |
All u2u's replied...
Pat....
Humbug
| posted on 28/9/08 at 08:17 PM |
 if they are the toothed looking things, they look a bit painful!
[Edited on 28.09.2008 by Humbug]
james h
| posted on 28/9/08 at 11:51 PM |
u2u re cable ends
James
