Master cylinder ID
kj - 23/6/13 at 12:55 PM
The master cylinder gave up last week got a new one for a siearra but the rear of the cylinder is bigger and means cutting and drilling new holes plus the pipe out lets are on the othe side.
The only makings it has S06 and its black i will add pic shortly.
It is from a Ford as per resivour
[Edited on 23/6/13 by kj]
kj - 23/6/13 at 01:27 PM
Other infor marked on the end is 1692 .22 its cast painted black and the end which goes into the bulk head is 33-34mm.
Waint for phone to up date to add pics
[img]
[/img]
[img]
[/img]
[img]
[/img]
davidimurray - 23/6/13 at 03:11 PM
You want a 22.2 girling master cylinder. Brakes international do them.don't get a bendix as they don't fit.guess how I know!!
kj - 23/6/13 at 04:03 PM
is that what is on the pics?
I guess i made the same mistake as you eh
justy75 - 28/6/13 at 08:56 PM
Hi there,
Sorry to hijack this thread, but I just wanted to know whether you had been happy with your level of braking with the Sierra master cylinder?
I have recently purchased a supercat and found the braking to be really poor. I have upgraded calipers and discs, and have found through the kind people in these forums that a: my greenstuff pads are less than desireable, and b: that the Sierra master cylinder is considered to be slightly to bigger bore, and that a smaller bore master cylinder will improve the braking considerably.
I am planning on changing to Mintex pads and adjusting the pivot point to see whether this makes a significant difference, and if it doesnt then the next step will be a master cylinder swap.
kj - 29/6/13 at 07:36 AM
Hi
not sure what pads is in it i think they are mintex, the sierra master cylinder did a good job, some people dont like the solid feel and went for a smaller fiesta one with a 19mm bore which gives a bit better feel.
