FOR SALE.
Single axle, converted caravan chassis. This trailer is in good condition and tows really well. It was overhauled in the summer of 2014, with new
brakes, new wheel arches and new jockey wheel fitted. I have probably used it less than 100 miles since all that work, hence the reason for sale.
Overall length approx 3098mm, width approx 1960mm. The bed is approx 2660mm by 1680mm. (please note distance between wheels is approx 1590mm)
The trailer has a winch fitted with steel cable. The trailer has been used regularly to move my Robinhood S7 and also my MX5, so I know both of those
fit.
Advertising on here first before Ebay....
£400, located in Gateshead, North East.
Pictures at : https://flic.kr/s/aHskd7u52Y
[Edited on 23/7/15 by Phil_neast]
Hi Phil
I'm interested.... can you give me accurate measurement width between wheelarches and length of bed....could be a bit tight for my MK..
Dave
I'm away with work for 48hrs but I'll get it measures and respond as soon as I get home. Please note the wheel arches have been made to be
quickly de mountable so the beat measurement is probably internal tyre to internal tyre.
Kind Regards. Phil
Ok Phil...thanks
Dave
The trailer is 1500mm between the mudguards. As I said the mudguards are designed for easy removal and that then gives you 1590mm to get your front
wheels on.
Hope that helps.
Phil
Hi Phil
I am also interested in the trailer. what weight is the empty trailer ?
Regards
Richard
Richard
If you follow the link to the pictures there is a photo of the trailer plate.
Kind Regards. Phil
Phil
Set you a U2U
Dave
Originally posted by skippad
Phil
Set you a U2U
Dave
Now SOLD. Thanks
