wanted bosch distributor plug for pinto
ragindave - 12/11/08 at 08:53 AM
I need the one in the picture with the red and yellow wires I only need the male part as the female plug is ok.
Any one got one, beer tokens at the ready.
Thasank you.
mcerd1 - 12/11/08 at 08:58 AM
I'll have a look
I should have a couple - if its the same on an EFI granada
what length of wire would you like ?
ragindave - 12/11/08 at 09:19 AM
Longer the better thank you
gavin174 - 12/11/08 at 10:59 AM
why not cut the plug off and solder straight through..
you can always remove the little plug from the dizzy if you need to rake the dizzy out
DarrenW - 12/11/08 at 12:14 PM
I just used spade connectors straight onto the terminals. Also used small cable tie to secure the wires.
mcerd1 - 15/11/08 at 03:41 PM
I've had a good look at all my ones now
I have got bosch distributors, but they must all be a later type than yours as they are nothing like that pic (mine have 3 wires and a different plug)
so sorry about that - I guess you cut off the old plug and fit a new one of any type you like
[Edited on 15/11/08 by mcerd1]
ragindave - 19/11/08 at 09:02 AM
Thanks for looking I am still after one if anyone can help
