Long shot - Type 9 Ali bellhousing
flak monkey - 19/11/08 at 08:15 PM
As the box is coming out at some point, I might as well shed a couple of KG at the same time.
Anyone got an ali bellhousing laying about for a T9 box?
hector - 19/11/08 at 09:01 PM
i believe i saw one on bay of the e last night...... I did a search for "ford 2.8"
may still be there!!
coozer - 19/11/08 at 09:33 PM
How much do you want to pay David? Theres brand new ones going for £170 from Tracsport, HERE
Price was quoted in Nov edition of ClassicFord.
I'm mighty tempted while I have mine out
mookaloid - 19/11/08 at 10:12 PM
slightly cheaper here
mookaloid - 19/11/08 at 10:20 PM
That one won't fit a pinto though....
flak monkey - 19/11/08 at 10:40 PM
Stupid question...what about the clutch release arm? There doesnt appear to be a place for one on that one on ebay...
snapper - 19/11/08 at 10:44 PM
RS 2000 item, I got one from Ford parts desk £20 something + VAT
Mr Whippy - 20/11/08 at 07:56 AM
standard bellhousings are a fare weight too, like that diff aswell great stuff
procomp - 20/11/08 at 08:25 AM
Hi
When buying a genuine ford RS 2000 item check them very carefully for being square across the gearbox and engine faces.
They are a rather fragile bit of kit and generally they distort if in a road accident etc. Problems that then arise and not usually straight off are. Front bearing on gearboxes knacker up in a short time and numerous clutch problems due to the drive plate not being aligned with the gearbox.
Cheers Matt
MikeRJ - 20/11/08 at 04:07 PM
They also tend to crack, and being alloy the chances of stripped threads is quite high on s/h items (but can be easily helicoiled).
Probably worth knowing that Rally Design sell new ones for £129+vat
