Hi all,
Before I order a brand spanker, has anybody got a hi torque pinto starter motor sat on their shelf? - is so let me know - beer vouchers waiting.
cheers,
Greg
what is wrong with a standard pinto starter motor? might save yourself a lot of money if you use standard instead of high torque
Y do you need a high torque? Is your car running exceptionally high compression or a tiny flywheel?
Standard ones are muchos cheaper!
I got one for mine from H&H as they worked out a bit cheaper the the likes of Burtons etc....
I reconned I might need it since I'm going to have a higher CR and only a 5.5kg flywheel - but even so I might have got away with a standard one
I've got a couple of used standard ones going spare if anyone needs one (not really worth posting them though)
[Edited on 30/11/08 by mcerd1]
One from an auto will have higher torque than a manual item . Hot rod boys used them .
my flywheel is 3.8 kgs! and i use a standard starter and have no probs turning it over
standard item (new refurb) fine starting from cold, but not happy when warm...
