Does anyone have a 20mm drill and pillar drill/lathe that i could use?
I'm fitting a breather to my cam cover. It's a -10 JIC fitting so needs a 7/8" thread tapping. The tap says use a 20.4 drill but my
pillar drill only goes up to 16mm. Can anyone help? Just need to dill one hole!
I'm in St Albans, Herts. but happy to travel.
TIA
Ben
what about a local engineering firm the one near me is really helpfull and will drill the odd hole for me for the cost of a pint give that a go you never know.
got one in rushden northants if no-one closer
dave
I'm fitting a breather to my cam cover. It's a -10 JIC fitting so needs a 7/8" thread tapping. The tap says use a 20.4 drill but my pillar drill only goes up to 16mm. Can anyone help? Just need to dill one hole!
TIA
Ben
im in letchworth and im pretty sure i have a 20mm holesaw drop me a u2u if u still need help
Im in stevenage, let me take a look if you still need help ?
I will take a look at work too (letchworth)as we have an old school mill and loads of drill bits etc, work for inlaws so shouldnt be a prob.
Thanks for the responses guys.
Sean - that's excellent. Will check them out.
Carl and Andy - Much appreciated. I'll check out drills first and get back to you later if necessary.
Thanks again
Ben
Thanks again
Ben
