Help in Bristol, Tube bending and Brake flaring tool?
Mark G - 19/12/08 at 01:41 PM
Hi all.
I'm Located near Bristol and need to bend some 25mm tube for my cooling system. I only need 2 bends on seperate pipes. One is around 30 Degrees and the other around 20 Degrees. Does anyone have access to a bender or know of anywhere I may be able to go to get them done? The closer to Nailsea or Clevedon the better really.
Also I tried bleading out my brakes yesterday only to find that one of my brake pipe ends leaks (alot) so it needs to be cut off and flared again, Does anyone have one I may be able to borrow for a few hours please? Again, the closer to Nailsea or Clevedon the better.
Thanks in advance
Mark.
02GF74 - 19/12/08 at 01:54 PM
you are too far for me to do the flares for ya
as for the tube bending, did we find out how coozer did it?
cjtheman - 19/12/08 at 01:56 PM
hi i got a pipe bender in work
i also have a brake flaring tool
in south wales not far from newport
if you cant find anybody more local to you
cheers
colin
paulbeyer - 19/12/08 at 04:45 PM
Mark,
I have a plumbers pipe bender and a brake flaring tool in Thornbury if your interested.
Paul
Mark G - 22/12/08 at 07:19 PM
Originally posted by paulbeyer
Mark,
Paul
You have u2u.
[Edited on 22/12/08 by Mark G]
