Hi
going to be megasquirting my crossflow soon
has anyone got a spare or unwanted crossflow crank pulley with trigger wheel fitted. thought id ask befor buying a new one.
thanks
Mark
If you can get hold of a crank pulley from a 1.8 cvh from a scrappy you should be able to make your own. The cvh has a ring on the pulley that can be
removed and you should be able to weld it onto your crossflow pulley.
Stu
I used a wheel from trigger wheels , made up a spacer to fit into the steel crank pulley to which I doweled the trigger wheel when I was happy with the position . Helps to mount the sensor before positioning the T/W. Don't bother using a standard X flow pulley as they self destruct at high revs, use a steel one
