A mate of mine with a westy is after a sump for his 1700 x flow. I'm not sure on similarities between x flow engines so maybe any x flow sump
will do?
Anyway, if anyones got one please let me know and we can discuss a price.
cheers
he needs a 1600 sump or a 1300 sump with 4 holes cut in it to clear the crank
Cue stupid alcohol induced silly reply.......
Wont the oil run out with 4 holes in it?
YES
Originally posted by MikeR
he needs a 1600 sump or a 1300 sump with 4 holes cut in it to clear the crank![]()
it will but if you have a bucket beneath and pump the oil back up, there should be no problem.
I have a 1600 engine that is seized due to the oil filter coming loose in my garage. If you take the whole engine you can have it for nothing.
Ian
Ian
