Hi guy's has anyone got one of these? I've managed to break a bit off mine!
Cheers Tom!
link
[Edited on 6/2/09 by tomblyth]
Originally posted by roadrunner
Is it an adjustable one, if so maybe!
Will need to check
Adrian
p.s. that dog stare is spooky!
[Edited on 6-2-09 by AdrianH]
yes its the adjustable one I broke the bit off that holds the horn carbon brushes and mounts the switch!
Got one in the garage from a MK1. Unfortunatly for you its not adjustable!
Unfortunately the one in the garage is also damaged around the steering lock section and mountings.
The lock section I think will swap from a non adjustable!
Adrian
i've just chopped one up! - youre welcome to the remains
http://www.tr3m5.com/images/cutsurround.JPG
[Edited on 7/2/2009 by Trems]
Thank lads I've sent U2Us Im goint to try and build one that fits out of all your bits if thats OK!
cheers Tom
