WTD - Small piece of carbon fibre / similar
spdpug98 - 2/3/09 at 02:48 PM
After being a complete @$!@ and messing up the holes on my tunnel cover for the savage switches......
I am after a small piece of carbon fibre or similar approx 10cm x 15cm, beer tokens await anyone who can help
Please help me cover up my @$!@ of a mistake
Mr Whippy - 2/3/09 at 02:54 PM
Best with a close up photo and a ruler to try and match the weave. Lets have a look and maybe we can come up with an alternative solution. Its best to use a piece of card or hardboard to sort the layout on, then transfer that over to the real thing once your happy its ok
spdpug98 - 2/3/09 at 03:01 PM
I wasn't going to tell what I had done as it is @$$$!@@ stupid!!!!!!!!!
But here goes....
I had marked out both the scuttle and tunnel cover for the switches and clocks. I did the scuttle no problem with the small hole saw and then needed some large holes for the clocks to fit so changed the hole saw....went and made a cup of coffee came out to do the tunnel cover.....can you see where this is going!!! YES - I forgot to change back to the smaller holesaw!!
The holes are now 25mm diameter instead of 22mm, so I just want small piece of carbon to cut out 22mm holes and place over the oversize holes
Edited to add: Tunnel cover is not carbon but Blue with a Black inset top
[Edited on 2/3/09 by spdpug98]
Phil.J - 2/3/09 at 03:05 PM
Why not make some nice shiny aluminium bezels to reduce the hole size?
spdpug98 - 2/3/09 at 03:12 PM
They already sit in nice shiney aluminium bezels, didn't want to extend the shiney area
iiyama - 2/3/09 at 03:15 PM
Mate, drop round for a brew and a browse, got plenty of off cuts kicking around.....
Ian
spdpug98 - 2/3/09 at 03:20 PM
Ian
Thanks mate, drop me a u2u with your address and when it's OK, and i'll pop round
Dave
spdpug98 - 5/3/09 at 02:32 PM
Ian
Ian, thanks very much for the carbon fibre - will buy you a beer at the Barleycorn
iiyama - 6/3/09 at 09:18 AM
Welcome!
