Wanted/borrow R1 air box mounted sensor
bassett - 6/5/09 at 12:49 PM
Hi, Im currently running a suzuki sensor to mount to my airbox but im having emissions issues and wondering if it stems from this so has anyone got a r1(02-03) 5pW air box sensor i could buy/borrow to test my emissions so i can get it through its sva retest
Adam
omega0684 - 6/5/09 at 01:08 PM
i have,its from 02/03 5pw as well, thats convenient isn't it, £10 posted
[Edited on 6/5/09 by omega0684]
spdpug98 - 6/5/09 at 01:54 PM
Adam
You are more than welcome to borrow mine, dependant on your re-test date and mine - but not sure if mine was the proper one as I had to trim the end of the fitting to fit into the connector block
I am also happy to send across the map which I passed emissions on last week, it was the same map as Rob's map but with a few minor tweeks here and there
Dave
bassett - 6/5/09 at 06:05 PM
Omega - u2u sent - would be great if you could get that to us.
Dave - thanks for the offer but il buy one if possible as if our suzuki one isnt correct were going to need one for long term reliability/performance. As for mapping im just about used to the configuration so using il start from scratch on a stock r1 map then adjusting to suit on the rollers as after the last session it really does show its the best way. At the same time hoping to get a power map set up
Adam
[Edited on 6/5/09 by bassett]
