Hi, time has come to re-do the plumbing, so i'm after some coolant pipe/hose.
It needs to be 32mm ID hose, or 32mm OD solid pipe. Not too sure what i need, definately some 90 bends, so what have you? Flexi hose is also on the
list.
I think it's looking like some bends, and short joiners, so don't be shy and i'll see what i can use.
Thanks y'all.
I splashed out on silicone hose, off ebay.
thermostat is 38->32 mm right andle reducer, water pump is two 90 degree right angle with 32 mm aluminium joiner.
water pump to manifold is 18 mm hose
and from another angle...
you can get 32mm hose wth a metal spirial built in. you can have a serious bend and the spirial will keep the wall from collapsing.
Darren
Thanks for the help peeps.
I've had a mooch round, and have found many a place selling sutible pipework, but i was more wondering if anyone had any old or secondhand stuff.
Partially to re gain some pennies and to save me some while i perfect the plumbing before shelling out on expensive silcon jobbies.
Thanks again.
