Right men, who out there can help me solve my lack of box problem?
I have been chasing a lost cause, i have been trying to track down an mt-75 for my 2.9 cossie engine and the only ones out there are 4x4.
I now need a box that will fit and fast it has to have all the trimmings i:e flywheel,prop,starter and backing plate.
I am not sure if the 2.8 stuff will fit, thats were you lot come into this.
Please put me out of my misery before the rope does.
Thanks to anyone that can save me
Kieth
There seems to be a few peole breaking cossies. Not sure about the Scorpio cosworth, but there may be some on here
http://forums.turbosport.co.uk/bbs/postlist.php?Cat=&Board=PartsSale
Good luck
Theres an xr4i in my local free adds.
A reg spares or repair £50.
Tel;01525 384633.
I hope that helps.
Ray...
No connection.
thanks for your suggestion, i will certainly follow up on both of them and with luck my beast may live.
Keith,
Graceland's breaking a Scorpio Cossie, he may have what you're after!!
http://www.locostbuilders.co.uk/viewthread.php?tid=12169
James
The Cologne 2.9 v6 stuff fits the 2.8 but I'm not sure how similar the Cossie 2.9 and the Cologne 2.9 are. In any case, the gearbox internals
are the same as the 4 pot equivalents it's just the bellhousing and the input shaft that are longer.
I'm using a Capri v6 box on my (ex-XR4x4) Cologne 2.8. Fitted fine and seems ok although I've only driven it a few hundred yards on my
drive!
Chris
