Mornin' all
Does anyone have a 32mm tee with a 15mm takeoff lying around - or know anywhere I could get one on-line ?
Thanks in advance...............
shame it's 32mm not 30 otherwise you could probably use a 28mm-15mm-28mm unequal copper tee.....
Car builder solutions do them for 20quid (ouch)
Other way would probably be using a 32mm temperature gauge hose adaptor and drilling & tapping a for spigot connector on the side.
02GF74 has one, just. !
, but its not for sale sorry.
http://www.locostbuilders.co.uk/viewthread.php?tid=130980
Joe
[Edited on 28/2/10 by welderman]
deneo on here will make you one ! just u2u him or phone him tell him I gave you his number ! (number u2u'ed)
BES do reduced T's. I think that the 28mm is internal dim and then they have a Yorkshire fitting on so the 28mmx28mmx15mm should fit.
Don't use deneo whatever you do, his work is shoddy and he lies through his teeth - you have been warned!
