hi all
i need a steering column mount! not sure what it is called properly but i need one.
i have just realised i have made a very stupid mistake.
stripped my donor ages ago, been checking other peoples build pics and realised i have thrown away steering column mount.
in case i havent described it correctly its the bit which the steering colum fits through, then that is bolted to frame.
help would be very much appreciated
thanks
steve
If it's the Sierra column and you mean the alloy yoke with a pinch bolt and 2 mounting holes,then yes I have one you can have
it is the sierra one and that sounds like the one! how much would you like for it and would you post it?
thank you very much
steve
It's gathering dust. u2u me with your address
u2u sent
thanks
