I'm looking for Duratec connectors.
1 triggerwheel sensor connector
4 injector connetors (Bosch EV6)
and
clutch cover bolts (6 small ones)
Hi Micael
I have a set of injector connectors.
You can just use cap heads for the clutch cover if you want to. I think they are M8 from memory.
You have U2u
Dosen't the clutch cover bolts need to be in high strength (10.9/12.9 or so)
They should be 10.9, but cap head will be 12.9 anyway
When you say cap head, do you mean this type?
I'm trying to translate it to swedish terminology.
http://img.alibaba.com/photo/268425014/hexagon_socket_head_cap_bolt.jpg
Yep they are the ones
You can get the trigger wheel sensor connectors off ebay £4.99 I think
clutch cover bolts are M8 x 16mm
[Edited on 22/6/10 by big-vee-twin]
Thanks guys
