I have some nice chromed closed wheel nuts Ill fit ultimately but I need some open ones for mocking up just now cos the studs are overlength. Im
stuggling to find a set on ebay or whatever, theyre all for alloys. Does anyone have an old set lying they wouldnt mind parting with?
if is it standard M!2 thread, can you not use somethinig like this:
M12 studding connector ... or pad out the stud with washers?
you should get away with 2 bolts per wheel as it is just for rolling the car around.
^^^^ no good, due to pitch; how about £ 1 per nut?
here
[Edited on 21/7/10 by 02GF74]
