Hi peeps,
Looking for some Capri struts or Escort mk2 Rs Struts in good full working order.
Any help would be brill thanks peeps.
I have a pair of mk2 escort struts in the garage, how do i tell if they are rs ones?
as far as i know if they are rs struts they have inserts (the shocker should come out from strut casing) if it is non rs they are mcpherson and are one complete suspension unit like most vehichles. Thanks fella
I'll check tomorrow
thanks pal.
Hi, they are non rs ones, are they of any use to you?
unfortunately not fella. thanks very much for you're help though.
