need a rough piece of crap bonnet i can get some measurements off of and use as a rough template for the final one i make?
Anywhere is the southwestish. will travel to collect.
Cheers!
What about this?
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=144706
or do it by the book using a sheet of card then ali around a lamp post, yeh a lamp post.
Originally posted by kj
or do it by the book using a sheet of card then ali around a lamp post, yeh a lamp post.![]()
Ditto, I used lining paper to get the template then used 2 pieces of ally ('cos the pieces I took off the old caravan were not wide enough to
make a single piece bonnet
Like this:
JB
The one in the link looks to good to distroy really and bedfordshire over 4 hours away at legal speeds andd my mgb probably wouldnt like the journy.
On the other hand daddylonglegs your attempt looks pretty damn good! Ive made up a ally frame simlar to yours ill have to B&Q and have a play
tomorrow.... Its the last peice of the puzzle
Thanks!
Also is that green stuff you bonded to the ally, acyrlic? (however its spelt)
