As above, I need a pair of lower wishbones for my GTS Panther using Sierra Hubs.
Can anyone help?
Cheers, Neil.
I have a pair of lazer cut bottom arm plates , as per haynes book.
escort track or sierra..
I have a set off escort width..
They need to be Sierra track.
Cheers, Neil
you have a u2u
Thanks, reply sent.
Neil.
wozsher used to make them ....
dont know if he still does
If you know exactly what you want, you could go to a local fabricators and have them make them.
Alternatively, given your location, talk to Matt or Ivan at Procomp = 0121 350 3258.
[Edited on 4/11/10 by TimC]
Thanks Tim.
Didn't think of Procomp!
If I can't get them sorted I'll give them a call.
Originally posted by Yorkie
Thanks Tim.
Doubt it, he's not been on the site for over six months and
Last posted over a year ago.
Worth attempting to get them from GTS?
I say 'attempting' for a reason!!!
I still need a pair of lower wishbones (Sierra track) manufactured for my GTS if anyone can help.
I have the detail drawing that I could e-mail.
Cheers.
Dont Rally design still do them? I thought they were to GTS spec?
Paul
Cheers.
Thanks, I'll double check with RD tomorrow but I'm sure they are Cortina track which are shorter than the Sierra ones.
RD can supply either. Just check their stock on them first as i was sold mine and then had the long wait because of Darren not supplying them.
ETA RD will be at the Autosport show in a couple of weekends so you could save postage if you're going there.
[Edited on 5/1/11 by mistergrumpy]
Thanks to everyone that has helped.
The issue with the GTS wishbones has been sorted.
Hi Neil
glad you got sorted ..
