Wanted, 4 air horns/trumpets with dellorto/jenvey type bolt on fittings.
45mm diameter, and 25mm or so deep (I have some longer ones at 50mm and 65 mm if anybody wants a swap
Anything lurking in the garage?
Clive
[Edited on 14/12/10 by cliftyhanger]
Title had me thinking of Colonel Bogey
I've a spare set from jenvey at 40 mm long. Not quite what you need, but shorter than 50 or 65.
Originally posted by Dusty
I've a spare set from jenvey at 40 mm long. Not quite what you need, but shorter than 50 or 65.![]()
K+N's I will be using are the 63mm deep ones, so allowing for a fit of shrinkage 20mm clearance will be a little
too tight.
