Decompression plate wanted
lotusmadandy - 30/12/10 at 07:43 PM
This is a real long shot chaps but i am after a decompression
plate for my 2.0 blacktop zetec.
cash waiting
anyone?
[Edited on 30/12/10 by lotusmadandy]
otodb - 30/12/10 at 07:59 PM
Hi,
I will need a Decompression plate soon for my MGB engine & will probably have to buy one, & may get it from this guy, his e mail is:- miketanski@gmail.com , only downside is he will want a tad more than beer money. All the best with it though, let us know how you get on.
Brian.
lotusmadandy - 30/12/10 at 08:04 PM
Cheers for that info Brian.
I dont mind paying to get a plate,just thought i would
ask on here first
I will drop him a line and ask him.
cheers
blakep82 - 30/12/10 at 08:13 PM
what is a decompression plate? is it just a steel plate that goes between the block and head? contact andyw7de he might be able to sort something out for you.
do you need to use 2 gaskets with them?
lotusmadandy - 30/12/10 at 08:21 PM
hi Blake,
you are correct mate.It is a plate that goes between the block and head,
to lower the compression ratio when fitting a turbo/supercharger.
Some say use a pair of gaskets and some say to use one gasket with sealant
between the block and plate.
Some say that its a bodge as well but i will give it a go first
blakep82 - 30/12/10 at 08:25 PM
in which case, send andyw7de a gasket and i'm sure he'll be able to do you one, any thickness you like
lotusmadandy - 30/12/10 at 08:28 PM
Cheers Blake,i'll drop him a u2u.
Volvorsport - 30/12/10 at 08:29 PM
i bet cometic already have the design , and you can buy different thickness gaskets .
snapper - 30/12/10 at 08:29 PM
Depending on how much you want to spend, Cometic do some thick ones for turbo conversions
lotusmadandy - 30/12/10 at 08:37 PM
Thanks guy's,i'll have a look at cometic's web site.
BenB - 30/12/10 at 10:14 PM
Try Ferraday engineering. They were the ones I'm planning on using if I ever get my blower install done.
ChrisW - 31/12/10 at 12:03 AM
Is it the same as for a silver top? If so, I've got one. What's it worth? Is £30 too much?
Chris
lotusmadandy - 31/12/10 at 08:58 AM
u2u sent Chris
