As title.
I'm after 4 pieces of 1-1/2 nominal bore Sched 160 stainless pipe by 18mm long.
Can anyone suggest somewhere that may be able to help?
Thanks in advance
Neil
you could always bore a piece of solid bar
You will struggle to get stainless in sch 160. What's the application I may have sch120 low temp a333 c/s at work.
I have a few bits of 15/8" O/D S/St pipe that I had to make up my exhaust. No idea what Sched it is, but should be around 11/2" ID or nearly so. Yours if any good. Cheers Ray
They're for the clamp spacer rings at the head end of a bike engine exhaust so the grade isn't important only rustlessness.
They would be 48mm od by 34mm id (ish).
It would take forever to bore out solid SS bar on my modelmakers lathe
Thanks anyway chaps.
Neil
I'll see if I've got any of the material I used. It was too big on the ID but I knocked 4 pieces of tig wire into the gap to centralise it
and it left a perfect gap for welding.
Davie
Just a thought: wouldn't it be easier to get 20mm*3 strip and bend it to make your brackets?
Regards
Hugh
Thanks Davie
Putting tacks in the bore never occurred to me. Doh!
Neil
Hi Neil,
Sorry for the delay, today was the first of me getting to the garage. Unfortunately I can't find any of the pipe I used, I've been trawling
through my emails trying to find the invoice for the sizes but again I've drawn a blank. Sorry
Regards
Davie
EDIT for typo
[Edited on 29/1/11 by daviep]
Thanks for looking, you've given me an idea anyway.
Neil
