Not sure what year i need but i bought one and it doesnt fit past the steering wheel lock.
Any one got a spare, im fitting a quick release boss so dont need the colapsable part or the rubber cover.
can anyone direct me? suppliers wont risk sending the wrong one and most are £55
No one??
could put a photo up could help
I can, but its just a sierra column. ill get one this morning
Have you put the key in the ignition and turned it to disengage the lock?
Yea of course, its the innner ring on the boss its far too small.
Forgot too take pics yesterday, i ended up doing jobs for the neighbour. ill take one this morning, after cutting grass of course
Pics.....
Current Steering Wheel (sierra)
Current Column (sierra)
New Steering Wheel and Quick Release Rage Boss (6 x 70mm PCD on boss flange)
...as you can see the boss is quite deep, about 3 inches so i need the slimmest boss to fit between this and the column
I bought this one below marked up as FORD Et35 but its way to small and hits steering lock, i would order another if i was sure its the right one and
i would prefer one with a colapsable part that i can remove to make it more slim line
