Hi All,
For my next project, I'm after
Volvo 340/360 auto diff assembly
Volvo gearbox(that bolts onto the diff.
I'd also like the rear driveshafts as well.
Nev.
you want the CVT box ?
feckin huge .....
diff is located on the back of the manual box , on the cvt its part of an angle drive gear .
I want a manual box and diff firstly.
I'm told that there was an auto box as well as the cvt. It's the auto cwp that I'm after. 2.9 ratio I'm told. Doing a rwd front
engine special, using a bike engine, so want the long diff ratio, and keep the last couple of gears in the 'box and grind out the rest. This will
give me fwd/rev/and a step up with 5th.
Nev
all cvt mate........
not sure of the 2.9 diff fitting the manual box either .
sign up on v300 mania , youll find all you need on there .
Manual box was really huge too istr basically it was a version of the 140/240/260 box bolted to a diff unit.
The Variomatic was a laugh once encountered one that one of the half vee pulleys came off and rolled along the road over taking the car which was
grinding to a halt.
