sierra diff tool wanted please
andrew-theasby - 9/5/11 at 05:28 PM
Hi, does anyone have the tool for undoing the castleated lock rings on the output bearings on a 7" sierra diff, before i buy one, that i could buy or borrow please?
Sierra/Scorpio Diff bearing tool. Ford/Kitcar/Caterham | eBay UK
mookaloid - 9/5/11 at 05:34 PM
Ooh you're posh - I just use a bit of flat bar of suitable size held across the diameter and it gives enough purchase to undo the ring.
gavin174 - 9/5/11 at 05:54 PM
i have seen a very clever person use an old brake disc,
with 6mm bolts through it, in strategic places..
then turn the disc like a steering wheel
hope this makes sense.
if not will try and get some pics...
andrew-theasby - 9/5/11 at 06:02 PM
Just realised do i even need to undo these to remove the otput flanges, or are they circliped in (or similar) from the inside?
gavin174 - 9/5/11 at 06:13 PM
on the bolt on shafts you need to remove the rear cover and there is a circlip on the inside..
andrew-theasby - 9/5/11 at 06:24 PM
ok thanks, cancel that then, i dont need one now
