on the scrounge again
anyone have offcut of black carbon fibre cloth 60 x 80 mm they are not needing?
(it is for decorative purposes hence needs to be thin and flexible.)
thanks muchly.
Got a some 3m di noc if ok, send me your addy if its ok.
Just re read and you're after the cloth, so no sorry. Just got the self adhesive gear.
R
[Edited on 10/7/11 by RichardK]
Ive got a piece of woven carbon fibre cloth you are welcome to pop over & cut off a piece 60mm x 80mm if you need the bare cloth ?
Im in North Herts, if you need a thin bit of 'finished' carbon fibre then this wont be any good to you.
