WTD: chassi and bits
samjc - 30/7/11 at 10:08 PM
Hi im a noobie on the site and im idealy after a haynes roadster or similar chassi and bits to start my kit. Wanting a full indipendant suspension set up so any help will br apreciated.
david_hornet27 - 30/7/11 at 10:11 PM
If I had spare space I would be considering this...
LOCOST KIT CAR CHASSI | eBay
Not sure what anybody else thinks?
PSpirine - 30/7/11 at 10:20 PM
Thats not an independent rear end chassis.
Flat pack Haynes chassis are around £250 - fully built up around double that, so not that expensive.
If you give us a bit more info about what you want from the car and your build plans we could probably advise a bit better. Incidentally if you're looking for a more complete kit I'd consider looking at the GBS Zero (no experience with it myself, I've just looked into them)
mark chandler - 30/7/11 at 10:29 PM
Mines based upon the 1st edition book with home brew IRS, if I made again I would make it smaller not larger
That frame look fine but the rear end needs doing again, bending panels around those curves will look awkward, I chopped up some old steel chairs and used the curves off these, larger radius and even, adding IRS from is easy enough, plenty of plans lying around have a look here
Regards Mark
[Edited on 30/7/11 by mark chandler]
